Zoltar,
If you use the "tracker" when drawing then there is an option in the tracker settings to use "Relative co-ordinates in tracker".
If you don't use the tracker and instead use the co-ordinate palette then make sure the triangle (delta) buttons are pussed in (next to where you input the co-ordinates in the palette).
