2007-09-21
03:12 PM
- last edited on
2023-05-23
05:05 PM
by
Rubia Torres
2007-09-26 03:14 PM
Djordje wrote:well, i thought i shouldn't but there they are when they are edited...xristina wrote:Then you should not have Other objects at all.
nope... custom objects are saved in the project library. When they are edited they are still within the project library... changes are overritten...
the path points to the project specific library...
See how do you load your libraries from the server?
2007-09-27 04:13 AM
2009-01-28 05:21 PM
2009-01-28 06:10 PM
2009-01-29 10:58 AM
Stuart wrote:Stuart, thanks for the suggestion, we will try this, but as my colleague just pointed out to me, this issue also occurs at the tiem of the .gsm's creation. So I will choose the location and save it in there (eg, stair xy saved in project library folder) and then when I open the file the next morning, said stair xy will be loaded from the project library folder and in other objects in the Library manager.
i have a vague memory of having a similar problem when playing with liibraries a few years ago.
As a test, instead of just clicking "save", click on the "save as". This makes ArchiCAD assume you are saving it elsewhere and therefore it forces you to browse to the location you want to save to.
Browse to your project specific folder and overwrite the existing object.
That might fix the problem.
Cheers
Stuart
2009-01-29 11:47 AM
2009-01-29 11:58 AM
2009-01-29 01:47 PM
2009-01-29 05:50 PM
laszlonagy wrote:Lazlo, I am not talking about modifying standard ac lib parts.
It is a recommended way of working that if you modify any standard ArchiCAD Library Parts, you should save it under a different name.
If you want to overwrite it permanently in the LCF, then extract the LCF, modify the Library Part in the extracted folder, then recreate the LCF file from the extracted Library Folder. Then delete the extracted folder and keep using the LCF file.
2009-01-29 08:43 PM
