Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. License Manager Tool update is required on Windows. Learn more…
"Bent" section line
Hi
I have a building that is at an angle in plan.
I'm wondering whether I am able to draw a single section using the section tool that is "bent" to follow the angle of the building, like the attached.
Is this possible?
Ben
No.
The best you can do is to place 2 separate sections.
Then join them together in your layout.
No.
OK, thanks Barry
