"Single Slope 10" Object Question
We are trying to use the Single Slope 10 object in Object Library 10.lcf -> 05 Metals 10 -> Steel Structure 10 -> Frames 10 and we can't figure out how to slope the tops of the columns. The icon seems to show the frame with sloped plates at the tops of the columns, but there aren't any settings for this, are there?
I just checked and the slope of the tops of the columns
is controlled by two parameters way down the list
called Decreased left column eave height and
Decreased right column eave height.
Peter Devlin
There aren't any "Descrease..." parameters in the object, but I created an elevation and they can be adjusted in there. When you click on the outer-most hotspots, it comes up with "decrease Left..." So you were right about the parameter, but I can only access the parameter in an elevation window.
Thanks!
