reshaping a window
Hi
Can anyone suggest how I can get rid of the bit of window that sticks out at the bottom?
Tried SEO and that doesn't work
Cheers
Adri
4 REPLIES 4
Try the Design/Solid Elements Operations and Subtraction
that doesn't work. you can't select the window as a target for SEO
Don't use windows. Prefer the object Curtain Wall
Link
You'll need to use the Trim to Roof command.
Link
