jespizua
roof error_magic wand related.
Hello,
I´ve been suffering some troubleshooting when using roof (barred vaulted method) using magic wand to define the roof profile. The error is the next:
The curve you defined as the roof profile results in reclinate roof planes. Roof curves extending beyond vertical are not allowed.
I´ve tested with a lot of shapes, no matter if i use polylines or splines, always the same error.
Thanks in advance.
osx 10.14 | archicad 22 | cinema4d 18 |
4 Replies 4
Thomas Holm
Use a wall with a complex profile instead.
http://archicad-talk.graphisoft.com/viewtopic.php?p=108610#108610
jespizua
Thanks for the reply Thomas. I know that can be done with complex profile, but my question is why that error?, i´m pretty sure that can be done using roof more magig wand(Lazzlo made that in virtual tutor 10), and don´t know if is an AC 11 bug or my fault.
Link
ArchiCAD is trying to 'help' you.
It is telling you that you can't have a roof that goes underneath itself. Maybe the image will explain it better....
Link.
jespizua
Thanks Link!!
