roof stripes wanted !
helo again !
I succeeded in creating a roof...but I want it to be with stripes (polygons) like in this pic....how can I do it? the roof parameters are quite empty this time
I don`t want to texturize it later...I want it to be polygonal.
5 Replies 5
Your attachment didn't work. Don't see any picture. And you should still put a signature in your Profile ( upper right hand corner ) and put in your computer specs and Archicad version etc. Helps in answering your questions more precisely.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
Hi Pilgonico,
I'm guessing that you mean a standing seam roof?
Try using the roof accessory tool. You may need to download both the accessories goodies and the accessories library if you haven't done so already. The link to the 'goodies' is on your 'help' menu in ArchiCAD.
Follow the instructions in the readme for installation and usage.
thanks Peter ! that`s it...but can not get the link !
can u right here the link? pls?
It's the 12th one down on the Help menu.
I can't post the link as I don't know what localised version you use, and I don't know the version number of ArchiCAD you use!
that works !!! Peter thank a lot mate !!!
