roofs
I'm using ArchiCad 14 student version. I want to dictate the height of each corner of my roof. On two sides it joins other roofs which are at different angles and and at different heights. I want this roof that I'm trying to draw to join up on both sides with what is already there.
Any ideas how to make this work?
Thank you
You can set out your roof in 3D window with 3 known points and it will calculate the roof angle and pivot line location for you, or stretch an existing roof in section to the required angle using the pet palette options
