ā2014-11-2001:28 AM - last edited on ā2023-05-2304:23 PM by Rubia Torres
ā2014-11-2001:28 AM
I'm new to ArchiCAD. I am trying to make a corbel column cap. I drew it in plan with the mesh tool and extruded it up. Now I need to rotate it on the y axis and it seems to only rotate on the z axis.
How can I fix this? Is there a better way to create the object?
Assuming you're using AC16 or later, select the mesh, right click and "Convert selection to Morph". You can now rotate in any direction you wish in 3D window.
