saving screen background color
Sorry if this is an obvious question, haven't found the answer.
How can i save/make persistent my screen background color (medium gray). I can't see where I can add this to my work environment schemes/profile.
Thanks for any help.
8 Replies 8
Erika Epstein
View> Grid Options> Grids & Backgrounds
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Hi Paul,
This is a per-file setting, not a global (work environment) one, so you cannot make this persistent across projects.
Karl
Karl wrote:
Hi Paul,
Karl
Ok, thanks for letting me know, sorry to learn (esp because if I save the file with my grid options, the next person to open it has to then change to preferred grid options...), but better to know. Thanks again
Link
If you teamwork the file, then each teammate can have their own unique background color within the same project.
Link.
Link.
Thank you very much, I didn't know that. I enjoy working in Teamwork (with all its complications - our projects are small, and we are few, hard to justify imposing TW) so I look forward to trying. Regards,
Paul
MMontgomery
I would also suggest making the background change to your template if you use one. This will start each project with the background color you want.
AC 6-29 - Ryzen9 9950X / 96GB RAM / RTX 5090 / Win 11 Pro
Right, thanks, we do use a template, but I don't want to impose my preferred background color on other users. So I guess TW is the best option.
Link
You will need to make sure that your pen colors suit all the prospective background colors and since there's no way to make every color work, you'll need to limit the range of allowable background colors in your office.
Link.
