shortcut to last command
Is there a short cut to repeat the last command? I'm not having much luck with the Help file today.
Thanks,
Jason
Command(Apple) or Control + B is the default.
Or any other keyboard shortcut you define for it in Options\Customize\Keyboard Shortcuts.
Laszlo
Link
And AFAIR, this will only repeat commands in the Edit menu (which is probably why it is in there! )
Link.
