skin priority doesn't work with SEO
heathldesign
I am trying to get proper skin connections between walls and a roof but i'm getting weird results. I have legacy mode turned off. if i use SEO the skins don't connect properly no matter what i do with the priorities.
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
3 REPLIES 3
heathldesign
if i use merge or trim to roof then the skins cut properly, but the outer two skins disappear.
Katalin Borszeki
HI!
You can create a proper connection if you Merge the 2 roofs first, then trim the wall with the merged roofs.
See the screenshot below for reference!
Best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
heathldesign
Thanks katalin, I'm away from the office until August,but I'll give it a try when I'm done playing in Austria
