slabs and walls ?????
I have a problem with slabs and walls because they are joined
If slab and wall have layers of the same fill, and slab edge is exactly the same place and the same length as wall base line, and slab is iter over ar directly under the wall, the layers are joined and part of slabs edge line is lost.
I of course do not want them to be joined, but I also do not want to move my wall base line, basically I can't move it because when I do walls do not join properly.
I have tried to change layer groups of slab and walls to different values and even 0 but it doesn't help.
Can somebody tel me if there is any ay to avoid this kind of behavior?
I mostly need to use empty fill that unfortunately can not be copied.
Cris
Stephen Dolbee
Cris,
Using different materials for the wall and slab edge should give you your line. (In elevation).
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
I do not want this line in elevation but in section
Cris
Cris
Then use different section fills.
