stair questions
hi there. i have several problems/questions with stairs that i am trying to build.
1. is there any way to create non-square stairs? i need to create a staircase with treads being more polygon shaped than rectilinear. is there any way to do this? and can the last tread be modified independently or do i have to make a separate staircase for a special shaped tread?
2. is there a way to reverse the arrow on archicad stairs? i want to show stairs going down, not up on a plan. surely there is a way to do this that i have just overlooked?
3. i have a switchback stair that looks great except that i have some free floating risers in space. i don't know what's wrong and i don't know how to take a picture of the screen to show my dilemma.
any help is greatly appreciated. thanks!
3 Replies 3
Steve Jepson
You can make the stair exactly how you want it. There are many ways to make a stair. If your stair is very unique you may want to model it from slabs, walls, or even a mesh, depending on what your stair is like.
If you could post a screen shot of your stair I am sure you would get some recommendations on which method to use.
More often than not, I model the stair with slabs and walls. I draw the stringers in section and turn them into library parts. I use slabs for treads and walls for risers. Same with hand rails. I use the profiler tool and save them as parts.
show us you stair if you can.
thanks. i just went ahead and made the skewed step with a slab. i just thought there might be something i was missing without having to buy add-on software.
Steve Jepson
the stair maker add-on does work very well. Do you have it loaded?
