story setting help
hi everybody
i need help with stories
i have 2 building in story one A & B
building B is two floors and bldg A is a single floor.
I want to be able to see the roof plan of bldg A(single story) when i am at the second story of Bldg.B...
Can anyone help me with that command/setting..
thank u
kaykay
3 Replies 3
Link
Cut the roof out and paste it onto the story you want to see it on. You will have to elevate it all down to the correct height (you can do this before you okay the paste or afterwards). You will also need to redo any Solid Element Operations if you have performed any with those roofs.
That's how ArchiCAD stories work - you place information on the stories you want them to appear on them. Their actual elevation is a separate issue.
Hope that helps.
Link.
Select all the roof planes for Bldg A and select the show on story settings and set to what you want.
Grant
thank u for ur input
it was quite helpful in solving the problem
kaykay
