‎2004-05-23
09:06 PM
‎2025-01-30
12:52 PM
Molinda Prey
‎2004-05-23 09:38 PM
‎2004-05-24 01:21 AM
Millard wrote:what he said, and:
Two different ways come to mind. Either select the area that you need to stretch with the marquee and then stretch; or use the adjust command -select the lines to stretch and then select a existing wall, line or draw a new adjustment line. Note that the fat marquee will stretch all of the stories at the same time and this may or may not be what you want.
‎2004-05-25 02:45 AM
‎2004-05-25 04:25 AM
~/archiben wrote:Doesn't it seem that a coincident floor slab (e.g.) corner point should also move when you adjust a wall corner this way? (And ceiling slab, zones, fills, etc. ... anything with coincident vertecies which would deform properly individually.) Granted, the arrow tool cannot be used to tweak non-walls... any other tool must be selected.
if your walls meet at a single node and are grouped, just suspend grouping and drag the node from one of the walls, the other will follow . . .
‎2004-05-25 11:11 AM
Mark wrote:well so they do! i always thought that the elements had to be part of a group to act as a polyline to edit . . .
What's the difference if the walls are grouped or not? When I select more than one wall and adjust 1 of them using the pet pallet polygon tools the others adjust grouped or not. Am I missing something?
