teamwork in archicad
how do your company work in team in archicad?
use its teamwork tool? or use your own method? and what is your layering system?
and beside, when we work on a complex shopping arcade, the file become so heavy and slow, then we switch to other software instead of archicad.
actually, we hope we can finish a whole project by using archicad, but we can not stand the pain when using archicad sometimes. we believe in archicad, but for our experience, we just can't control archicad well.
20 Replies 20
Erika Epstein
If you are working alone, you can just sign in as Team Leader with exclusive access and work as you do solo in a pln. Teamwork even in a small office can be handy; when you have a deadline you can share the project and work on the same file, when the emergency is past you can work solo in teamwork as above or switch the project back to a pln.
You shouldn't need to be setting up different layers and layer combinations just to work in teamwork. If they are set up correctly so you can output drawings working solo, the same will work for teamwork when you are sharing the project.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
