lasse
text block width issues
When creating or editing a text block, the borders of the block extend the
full width of my monitor. If I create a block with predefined widths, it's
ok, but simply double clicking and starting a new one creates a "field" in
which it stretches from side to side full width of the monitor. Also,
editing a block will sometimes result in a impossible wide block that I
can't access the text editing pane, just the formatting pallettes. I have
done a new and reset and it works fine, but opening existing projects it is
still an issue. Any suggestions?
Lasse
(unnerved by updates since v.4.55)
3 Replies 3
Aussie John
Yes this was noted in an earlier thread. Myself and another user indicated it has happened. I dont think it has happened since going back to my G4 computer (we were both using a G5)- what is your set up (tip put it in your signature in your profile).
Cheers John
[/size]
lasse
Sage advice, however I wasn't present for the thread nor did I find one on my travels. Care to enlighten me to the fix (or at the very least an idea of where I can find this thread)?
Aussie John
I didnt link to a thread because not much was discussed except it does happen. No one offered any solution
Cheers John
[/size]
