trouble designing arches
am having trouble making arches or wall openings with pop out arch soffits in building designs for roman style, mission style or mexican architecture style please if some one could help me out with some advice or tips or tutorials
4 Replies 4
Dwight
Welcome to the forum.
I cannot visualize what you mean - can you post an image?
If you do so, you will certainly have a solution quickly.
Dwight Atkinson
here it is i circle it on red i 3d modeling this at SU hope this helps
Dwight
All three conditions can be solved using the Complex Profile feature with the wall tool.
Study the custom profile.
In making these applique forms, you make a fill shape to match the elevation of what you want to apply, turn that fill into a complex profile, and extrude that profile perpendicular to the applied face. It is a wide, shallow wall placed on the surface of a conventional wall.
Dwight Atkinson
thank you very much it help alot
