Gerry Leonor
v17 roof tool + stories below
the roof tool doesn't seem to work properly.
I’ve got a roof with a cover fill (Sheet Roof) & it is set to Custom 'Show on Stories":
• Outline to show to 3 stories down
• Cover fill to show on Home Story only.
on the home story, the outline looks fine, but 1 story below, the outline is still shown as a solid line. 2 stories below the Home Story, it finally shows the dashed line.
the cover fill is even weirder. on the home story it shows fine. but 1 story below the cover fill still shows up & is finally gone 2 stories below. what's weirder is that sometimes the cover fill doesn't show up at all. i have to select the roof, open it's settings, change nothing, click OK, then finally the Cover fill shows up -- on the Home story & the story below which i didn't want.
i did a New & Reset but it didn't fix anything.
any help is much appreciated.
https://discord.gg/XGHjyvutt8
1 Reply 1
David Maudlin
Gerard:
I think you will need to check the settings for the Floor Plan Cut Plane for the stories below the Home story.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
