vectoral hatching
this may have been covered elsewhere but i couldn't find it.
Is there any way of assigning a colour to the background of a vectoral hatch in archicad 13??
I know it is possible to it with cover fills but it seems you can only alter the hatch outline pen with vectoral hatching which is a bit rubbish!
thanks
jon
7 REPLIES 7
There is a background pen setting for all fill types.
where?!
David Maudlin
jon:
You need to post a fuller description of your issue. Where (plan, section, 3D?) are you viewing the fill, and how (fill tool, part of another element?) is the fill being added? Images always help.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
apologies, i am new to this. i think i have updated my profile now tho.
The issue I have is as follows:
when assigning a material to a wall, for example the wood siding dark, you will see that in 3d. Then in elevation settings i have the vectoral hatch ticked so that you will get the horizontal planks showing which i was what I want. However I then cannot see a way in which to alter the colours of this hatch. Altering the uncut pen in the wall settings will change the outline and the lines in the hatch but I cannot see where to alter the background colour of the hatch or where it is picking that colour up from.
I am aware it is easily done in cover fills with the foreground and background pens but cannot see an obvious way of doing the same process for the vectoral hatches.
I hope this makes the issue I have a little clearer and appreciate any help!
jon
Jon
The colour in shaded elevations is determined by the material's Internal Engine "Surface colour".
And make sure in the Elevation / Section tool settings you have Fill uncut surfaces with... "Own material colours"
AMAZING!
thanks for your help! an easy solution-just knowing where to find it, the same as for many other issues for a newbie!
jon
Happy to help.
