SOLVED!
where is the consistency using the selection window
Hi all, if anyone knows why door, window, wall end & corner window can't be selected directly by the selection window, while the object (chair) & the opening can be selected? Thank you in advance.
AC 28 INT 5200/WIN 11
1 ACCEPTED SOLUTION
Solution
max_min
It's not just the window selection, you can't select them with ⌘+a either, unless you "activate" the tool first. This makes me think it has to do with the one thing these elements have in common; They must be hosted on walls, unlike objects such as chairs that can be placed independently.
Archicad likely prioritizes the selection of the host (the wall) over its dependent elements, meaning that when using a selection window, it interprets the input as selecting primary (standalone) elements rather than hosted components. This may be a safeguard to prevent unintended modifications, ensuring users don’t accidentally alter doors or windows when working with walls. Its probably similar reason why you cant select the subcomponents of a stair, railing, curtainwall tools.
I remember noticing this behavior when I was first starting out and feeling that it was unintuitive. However, it quickly became second nature, and I now see why its a useful safeguard—especially for beginners.
MacOs Sequoia | Archicad 13 to 29
4 REPLIES 4
Solution
max_min
The opening is a new tool and although similar to a window, does not belong to the wall in quite the same way.
It will have been programmed differently and is probably why you can select it by sweeping an area.
Doors, windows and wall ends belong only to a wall and must be selected individually or by selecting the wall they belong to (they will move or delete with that wall).
Or you can place a marquee, activate the window/door/wall end tool and press CTRL+A (or the mac equivalent).
Thanks @max_min & @Barry Kelly for your responses which is convincing for me as an Archicad old user but for any one is coming from Revit will find that selecting for window/door is a complicated way.
Yes, it prevents the accidental errors when dealing walls but I've to be able to select them individually without a marquess then activating the tool & CTRL+A or hovering over the door/win itself to select it.
Here's Revit is doing it smoothly; I think it's the time for creating doors & windows in separate layers while keeping their attachment to the wall.
Even Chief Architect can do it as expected & easily, don't know why Archicad is insisting to protect us from accidental errors,
Hey GS, don't worry we can handle those bad accidental errors 😉.
