Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
window help
I see now that many of my windows are inside out, but when I try to select them and flip them in the object settings nothing happens???
2 REPLIES 2
You mean you clicked on the wrong side of the wall? Rotate.
James Murray
yes appleE rotate command works, thank you
