vtomaz
How does it work?
1 Solution
If you don't find the answers to your questions in the Help documentation, it is best if you attend the webinar, where you will be able to ask the developers and product designers/managers themselves.
Go to post
4 Replies 4
This is a very broad question.
What exactly would you like to know?
Do you have access to it?
vtomaz
Hello. Yes, I have access and am trying to use the software. I would like more detailed instructions for each function and tool—specifically, how to perform tasks, rather than just a general introductory video. For instance, I imported a georeferenced survey (DXF file) into NC, but it did not align with the selected area. Furthermore, I cannot find a way to manage layers—specifically, how to assign this survey and other imported objects to a specific layer that I can toggle on or off. I also cannot find an option to view two "design options" simultaneously. These are just a few examples; there is much more I need to know. Essentially, I need to understand how to analyze the potential placement of structures—some with precise, fixed dimensions—within a large, empty site, and how to incorporate traffic areas and other paved surfaces.
There is the help documentation...
https://community.graphisoft.com/t5/Product-Help/Nemetschek-Creator-Help/ta-p/719052
There will also be a webinar on November 10 ...
https://community.graphisoft.com/t5/Graphisoft-Insights/Nemetschek-Creator-Early-Access-is-now-avail...
