Advanced Construction Site Container
gdubecz
We use this object not only to make the construction site model, but in some case we designed smaller buildings made of containers, as you can se on the picture. I couldn't find the object what I need on the Net , so I code one.
Comments
Rubia Torres
Thanks to @gdubecz, this object is now available for download on BIMcomponents. Click here to try it out.
At the end of the Parametric Factory stories, you can find a list of objects from the Community challenge to download as well.
Cheers!
