Sol4rpunk
Archicad 29 and Rhino 8 grasshopper connection issue
Hello hello,
Do you guys know how to make Archicad 29 work with Rhino 8? I can see it on the grasshopper plugins bar but not in the title bar (and so I can’t activate the connection) .. If someone has a clue and managed to make it work… Thank you !
Have a nice day.
Nurbs
Hi Sol4rpunk,
If you're looking for some help here there is more information needed. Which OS(WIN or Mac),Screenshots of the issue and so on...
AC16 - AC29, Rhino 5-8. Alienware WIN 11
It works fine for me with Archicad 29 and Rhino 8.
I usually start Archicad, open the file I want to connect with Grasshopper. Then, I start Rhino, start Grasshopper, and open the Grasshopper file I want to connect with Archicad.
Then, in Archicad, I bring up the Grasshopper palette (File > Interoperability > Grasshopper Connection menu commands), and click the Start button under "Sync Changes to GH".
Then, in Grasshopper, I bring up the Archicad Connection Palette (Archicad > Archicad Connection Palette menu command), and click the Start Connection button.
This normally establishes the connection between the two apps.
