Archicad Live Slab from Boundary Curves (mac)
I am trying to make a slab with a hole in Archicad using the surface from boundary curves in grasshopper. Grasshopper and rhino crashes when I connect the surface to the polygon AC component.
This is described as possible on AC (https://helpcenter.graphisoft.com/knowledgebase/74412/4 ) and I was wondering if this is a mac problem or an AC live issue.
Thanks,
3 Replies 3
Tried it on Windows and have the same issue.
Also another issue i've noticed, when intersecting a brep (a simple box) with a plane and feeding the resulting curve/s as input for zone/s, slab/s, wall/s, etc Rhino crashes.
If i rebuild the curve/s, everything is fine.
Tryed all of the above with same results on:
Archicad 23 + RH 6 (Windows)
Archicad 22 + RH 6 (Windows)
worked on:
Archicad 22 + RH5 (Mac)
Just following up in case anyone has some advice. Thanks Tudor,
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi All,
Thank you very much for reporting the issue and I am sorry about the experience!
Currently, we are investigating this problem and working on how to fix this. My first comment is, this may relate to both the Live Connection add-on and Rhino 6, therefore we may need an update for the add-on (and maybe ARCHICAD as well) in order for Rhino 6 to work properly with ARCHICAD!
I am very sorry about the situation! If you are working on an important project, I would suggest using Rhino 5 at the moment in order to avoid similar issues!
Thank you very much for your understanding! Have a nice Sunday!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
