We value your input!
Parametric design
About Rhino & Grasshopper and PARAM-O.
BIM and Visual Programming Survey
Hi All,
I am a part time student in the U.K. and I am conducting research into BIM and visual programming and I would be very grateful if you could complete my survey.
I am told by survey monkey that it should only take 15 minutes. I will also be posting the completed PDF report to this forum for those interested.
https://www.surveymonkey.co.uk/r/WRSBGBT
Please share and take part
Thanks very much, Simon
1 REPLY 1
furtonb
Hello Simon,
The survey is closed by now. Would you mind sharing the results?:)
odv.hu | actively using: AC25-27 INT | Rhino6-8 | macOS @ apple silicon / win10 x64
