Building Material Selection Crash - GH AC20 Live Conn Mac
Rhino WIP keeps crashing with Grasshopper - ArchiCAD Live Connection Beta version when a Building Material selection attempt is performed in the Wall Settings Component:
1. The Wall Settings Component is placed in the Grasshopper canvas.
2. Right click over "Building Material".
3. Click in the "Set one Building Material" option of the pop up menu.
4. Crash.
3 Replies 3
davdelven
I have the same problem with Composites and Surfaces component, but still not with Building Materials. Curious...
Maybe it's a bug ?
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
Have you found out the problem? since i have similar problem too, got crashed when building material and surface node if clicked.
Seems like a known issue in Mac version only. Its also clashing with complex profiles.
As per support feedback channel, its a known bug #229776
