rav668
Param-O Value of a variable in range
Hello Community!
I am looking for a way to lock the value of a parameter in range without going into GDL code (in Param-O). I would be grateful if someone could share the solution to this problem,
Best regards,
Rafał Rucki.
Marc H
Hi Rafal,
You can see if the Min node between your Dim (or a Length) node and your shape size fits your needs. Variable ‘B’ will be a Length node set with your maximum value and set to false (visibility).
(Note: This will still allow an excess value to display in the Dim or editable Length dialog box.)
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
DGSketcher
Legend
Best avoid using GDL as typing VALUES "A" RANGE [ 1.5, 6.5]  is far too complex to learn and takes ages to set up. 🙄
Sorry for the sarcasm but Param-O is the most pointless tool GS have ever generated.
