Parametric design
About Rhino & Grasshopper and PARAM-O.
delete elements when connection is off
I’ve deleted some elements in grasshopper when the connection between Grasshopper and ArchiCAD was off. Actually the ArchiCAD wasn’t open when I deleted elements. But now those elements are still in ArchiCAD and have no any access to them. I can’t change their setting, cant unlock them, cant delete them. I can’t do anything but selecting them. I will so thankful if anyone help me.
7 REPLIES 7
Which ARCHICAD version and Grasshopper Connection does this happen with?
Can you unlock or deleted them with the GH-AC Connections started?
Its ArchiCAD 22 and Grasshopper - ARCHICAD Live Connection 2.2 (22.0.6026) . no I can’t delete or unlock them with the GH-AC Connections started.
What happens if you open the file with the "Open & Repair selected file" option selected in the Open Dialog?
Does that fix this issue?
No it doesn’t fix it. It seems that it’s a bug.
Yes, it is very likely a bug.
What happens if you delete the Layers these elements are on? Are they then deleted?
Nope. there is no way to delete them
leceta
Are you using plugin interface (palette) to call unlock command? Did you try calling it from menu? (Edit-Locking-Unlock)
just guessing...
