Parametric design
About Rhino & Grasshopper and PARAM-O.
"Surface Attribute" (Grasshopper-ARCHICAD)
Help me please!
How to add, or what to connect "Surface Attribute"?
The manual doesn't say...
No one will say anything?
leceta
hi, use building material instead. Building material has a "surface" associated (among other attributes)
Thanks.
Found the answer yourself: "Currently, this Input Node is available for only the CW Frame Settings and CW Panel Settings components."
Well... We will wait for the application of surfaces in update Grasshopper-ARCHICAD Live
Connection 2.3
