Improved Grasshopper-Archicad Connection - Beam/Column
Boost your parametric design workflow with extended beam and column support thanks to the updated Rhino-Grasshopper-Archicad connection. The improvements include end cuts and vertical curves for beams and columns, allowing seamless and consistent interface between the two programs. With a number slider you can easily change the angle threshold to optimize your layout and split your reference geometries into separate groups to easily customize the details of the Archicad elements.... You can customize the top and the bottom of these elements.....or the cut angles to be horizontal, vertical, or a custom one. All these improvements add to the accuracy of the element geometry for a clear project communication.
Status
Delivered
Last updated: 2024-09-30
Explore the Wishlist
Can't find what you are looking for? Visit the Wishlist to see already collected wishes or Submit your wish
More info
