Improved Grasshopper-Archicad Connection - Hotlinks
Using Archicad’s Hotlink workflow, this feature helps you seamlessly work with repetitive components directly within Grasshopper. Just like in Archicad, in Grasshopper interface, you can insert hotlinks of plns, mod files or any other supported formats. Once the Hotlink is selected and an insertion point is defined, you can play with the other parameters within the Hotlink settings dialogue, such as the rotation of each hot link.... You can also update each hotlink within Grasshopper, as Grasshopper is responsible for the position in placement parameters.
Status
Delivered
Last updated: 2024-09-30
Explore the Wishlist
Can't find what you are looking for? Visit the Wishlist to see already collected wishes or Submit your wish
More info
