Set Resolution for 3D Views
If you use 3D views on Layouts for easier visualization compared to creating renders, you’ll be able to increase the resolution of 3D window images on output, no workarounds needed. When placing 3D Views on Layouts, you can now generate high-DPI images without needing to enlarge the window itself – a limitation especially relevant on macOS due to screen size constraints. As Physically Based Rendering continues to evolve and 3D views remain a widely used drawing type, being able to set resolution directly will simplify your workflow and ensure consistency across features.
2 Announcements
Molinda Prey
Status changed to: Coming soon
Noemi Balogh
Status changed to: Delivered
Status
Delivered
Last updated: 2025-10-01
Explore the Wishlist
Can't find what you are looking for? Visit the Wishlist to see already collected wishes or Submit your wish
More info
