Pressure loss calculation for ventilation systems determines the total pressure drop along each duct path based on airflow, duct dimensions, fittings, and components. It automatically evaluates friction and dynamic losses, identifies the critical (worst) path, and provides the balancing data directly from the BIM model.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Can't find what you are looking for? Visit the Wishlist to see already collected wishes or Submit your wish
