Are PDF Files actually embedded, or not??
When I open a file that has PDF files embedded, and those files are not in the same folder structure as they were when the .pln was created I get a dialogue box asking where they are. But even I select Skip, the files still appear in the plans and elevations.
So are the PDF actually embedded within the .pln file. Are the hotlinks only required for updated version of the files?
Is there no need to send the PDF files along with the .pln when you want to send it to another ArchiCAD user?
0 Replies 0
