BIM Planning guideline
We are looking for a BIM planning guideline. Does anyone know of anything like that? This would encompass detailed planning the BIM project and include plans for interoperability, uses of the model, and so on.
I've seen the "Big Building White paper" and similar kinds of "best practices". Just wondering of there is anything other guidelines that could provide some direction.
Thanks,
Brett
ArchiCAD 12 (since 7.0) Dell Precision M90 Dual-Core Xeon-2.33GHz/2GB RAM/512MB nVidia Quadro FX 2500M
7 Replies 7
Aaron Bourgoin
One piece of the puzzle would be VICO's (I think this is VICO's) notion of a Model Progression Specification.
Architecture is a process of articulation and specification. This notion is a great way to think of BIM as a process - that is to say that you don't have to and shouldn't have to decide everything today. This tendency is THE BIGGEST misconception anyone can have as to what parametric design software is or should be. The MPS is one framework that assists in this regard because its about sequencing the work in a sustainable workflow. You could use this as is or adapt the idea to your own enterprise.
See also: http://www.buildingsmartalliance.org/nbims/
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Laura Yanoviak
Try the BIM Handbook by Chuck Eastman, et al. It's a must-read for anyone working with BIM.
Thanks for the posts.
- We already own the BIM Handbook. It is a useful resource.
- I found the VICO outline. It will be useful as well. It is similar to AIA's E202 protocol exhibit.
If anyone else has additional resources, I am open for additional suggestions.
Link
Does the BIM Guide Series from the GSA help?
There's also Resources at the bottom of this page by John Stebbins:
http://www.digitalvis.com/bim/
Just to name a couple.
Link.
FYI - I found the BEST planning guide for BIM. It appears to be a Grad Student's work and not quite complete yet, but extremely thorough.
http://bimex.wikispaces.com/
There are also various resources and links on www.everythingbim.com
Rob Oberle
Thanks for all your suggestions. The "other software" platform also has a fairly generic guide that is fairly complete . . . Copy the following link:
http://au.autodesk.com/?autodownload=../orig/class_questions/thread__1356/Autodesk-AEC---Communicati...
