Change master layer of hotlink
Is there a way to change the master layer of a hotlink after it has been placed. I can't seem to find a way and can't find an answer in the any of the references. Thanks for any help!
Rob
Alika,
you can, it is a trick... you have to select the module on the plan and then go to the File menu you will find there an item Module Settings... that will do what you are after. But you have to have the module selected otherwise you will not be able to see that option.
how is the surf there?
::rk
Thanks Rob - figured it was going to be something simple.
Surfed this morning - small, but the wind was down and always nice to get wet.
