ā2007-03-29
12:41 AM
- last edited on
ā2023-05-30
12:58 PM
by
Rubia Torres
ā2007-03-29 12:50 AM
ā2007-03-30 12:19 AM
design wrote:Perhaps you are placing your dimensions all on one layer. You don't have to do this. Place the dimensions on the same layer as the element to which they relate. Alternatively, if you need the flexibility to be able to choose whether the dimensions are visible independently of the elements, then create several different layers, appropriately named to classify different sets of dimensions. You will need to create layer groups to suit.
How do I keep foundation layer dimensions from appearing on the floor plan layer........or how do I keep dimensions specific to each layer?
ā2007-04-03 05:55 PM
design wrote:The Quick Layers Palette will help.
ā2007-04-04 01:02 PM
design wrote:Sounds like you may want to consider placing your foundations on a separate story - then you can keep your dimensions on the same layer. Is that feasible?
