2010-01-06 04:44 PM
2010-07-27 05:54 PM
2013-02-20 11:48 PM
2013-02-21 01:04 AM
ares997 wrote:Works fine for me.
Really? I can't create an attributes file with the the texture and materials that I want and then import it into another file?
2013-02-21 01:16 AM
2013-02-21 02:52 AM
2013-02-21 05:01 AM
2013-02-21 07:17 PM
Dwight wrote:An extra step to manage (but a great strategy to reduce project libraries)... Clever! And the undo issue might not be a big deal if you have incremental backups! Was this trick published on the LW book or your Artlantis one? Thanks for sharing.
BTW: Dwight's Library Image Management Trick #39
I developed this trick in doing my first book, making many texture images to try material strategies and I had a gigantic library - reloading after every addition was just too slow.
To speed things up: Build a library folder with several dummy image files in it. Number them sequentially - or whatever. Once their addresses are loaded in the library, their content can be swapped without reloading. Just save the new image to an existing numbered file already loaded in the library. Archicad can't tell the difference. Nyuk nyuk. There's no undo so be careful.
2013-02-21 07:30 PM
