Project data & BIM
How to show 'Demolished' on plan but hide in 3D/elevation
Also is there a way to show elements that need to be demolished with custom override fill on floorplan, but to exclude these elements from showing in 3D and Elevations? I mean without using layer combinations, only renovation filter?
1 REPLY 1
On the floor plan use a renovation filter that 'Overrides' the 'to be demolished' elements, but in elevation and 3D you will use another reno filter that will "Hide' these elements.
