ā2012-08-05
10:55 AM
ā2024-12-31
02:19 PM
Molinda Prey
I am working on a subdivision and am trying to set up a structure
like this:
1.0 PRIVATE AREAS (zone category)
1.1 Low density residential (zone)
1.1.1 Phase 1 (sub-zone)
1.1.1.1 Lot 1A (sub-subzone)
1.1.1.2 Lot 1C
1.1.2 Phase 2 (sub-zone)
1.2 Medium density residential (zone)
1.3 High density residential (zone)
1.4 Commercial (zone)
2.0 COMMON AREAS (zone category)
2.1 Streets & roads (zone)
2,1.1 Paved area (sub-zone)
2.1.2 Sidewalks and curbs (sub-zone)
2.2 Public green space
2.3 Institutional
Eventually, I need the program to give me partial totals for each of the four tiers of data as well as a grand total which should check out with the parcel's total acreage.
In AC14, is it possible to add levels beyond the usual zones & sub-zones?
Are there any plugins that extend its capabilities?
If the answer is no, how would you handle this sort of situation?
And while we are discussing Zones, is there a way to isolate the urban-scale zones from building zones?
It just seems awkward and distracting to see all those zones called Living Room, Dining Room, etc. when you're working at an urban scale.
For that matter, I would go one step further and isolate the residential zones from commercial/industrial.
But I'm not sure Graphisoft has gone that far. If not, maybe I should submit it as a suggestion.
ā2012-08-06 04:11 AM
ā2012-08-06 05:32 AM
ā2012-08-06 06:26 AM
ā2012-08-06 06:47 AM
ā2012-08-06 07:40 AM
ā2012-08-06 12:07 PM
ā2012-08-06 06:56 PM
lsavinon wrote:The schedule can subtotal by any scheduled field(s) ... but not partial fields (e.g., not the first digit prefix of your zone code).
ā2012-08-09 01:15 AM
