Achille Pavlidis
Is there a way to transfer Renovation Override Styles?
As I see the Renovation Override Styles are a new Element Attribute, and as such should be also present on the Attribute Manager to allow the moving from one file to another. But they are not.
So how do we move the Override Styles created from one file to another?
Mac OS 26.1 | AC 29.1.0 INT 4006 FULL
5 Replies 5
owen
Deleted my first response as i was wrong
Although they are an element attribute they appear to be more like Model View Options - you can Import/Export via XML from the Renovation Filter Options dialog (see attached) ..
which doesn't actually answer you question - i assume the Renovation Override Styles are not exported with the above? (sorry undable to test at this moment)
os
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Yup. Just tested and the Renovation Override Styles are NOT exported - only the filters. Seems like an oversight.
Kind of an annoying dialog for export/import, too: you can only export a single filter at a time - no shift-clicking to export them all.
Renovation Override Styles should be (-edit-) exported with the Attribute Manager
Strange, I saw them with the other attributes, so I thought the attribute manager would do it, but it doesn't...
vfrontiers
Similar....
Can we change the NAME of the Renovation sections (Existing, Demo and New)?
I wouldn't care, but creating a SCHEDULE will only show by the heading given (Existing, To Be Demolished and New Construction)...
Anyone?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
vfrontiers
As there doesn't seem to be any other BUILT IN connection with these names, why not let us ADD additional categories...
Might be nice to have SITE DEMO, New and Existing so we could visualize them separately...
Duane
Visual Frontiers
AC3.14 - AC29
