Hi Liam,
I am not your Drafting Manager (but I may well be your CAD support if you are the Liam I am thinking of).
There is a pretty amazing coincidence happening if you are not who I think you are.
Whether you are or not I know exactly the situation you are in.
Yes there can be many hundreds of standard models, created over the years in various versions of Archicad.
And standard specifications change over that time so some of the content may be outdated.
And yes it can be a very expensive exercise to update all of the files, especially if some are not used so often.
I used to be a Drafting Manager, and my method back then and what I believe should be happening now is this.
Rather than update all files every time there is a version change or specification update do this.
If you need to use a standard plan that is an old version or needs updating, then make those changes and save it back as the standard model.
Now complete the job using that standard model.
You would have had to make these changes for the job anyway so it shouldn't be delaying the job any longer than it would have been.
And now you have an updated standard ready for the next time you need it - making the next job faster.
Rather than making the same changes for every job again and again.
This way the popular standards get updated and the ones that aren't use don't.
That is my view but your Drafting Manager may see it differently.
