Project data & BIM
Match Properties
Is there a way to match the properties of existing layers, linetypes, text, etc. on your drawing? I see holding down ALT will give you the eyedropper tool which will assume properties of the next item you select, but how do I change 'text a' to the properties of 'text b' without going into 'text a' and editing?
Thanks,
Jason
1 REPLY 1
Found it!
Apply Elements' Settings:[Cmd/Ctrl]-[Alt/Opt]-click element
