2004-04-1406:53 PM - last edited on 2023-05-3001:16 PM by Rubia Torres
Match Properties
2004-04-1406:53 PM
Is there a way to match the properties of existing layers, linetypes, text, etc. on your drawing? I see holding down ALT will give you the eyedropper tool which will assume properties of the next item you select, but how do I change 'text a' to the properties of 'text b' without going into 'text a' and editing?
