‎2019-08-14 10:34 PM
‎2019-08-15 01:01 PM
Noémi Balogh
Senior Community Expert, Admin
‎2019-08-15 05:56 PM
nbalogh wrote:And, to find out if your project is heavy with polygons...and if so, which objects are responsible (and should be deleted or simplified), get the PolyCount add-on which is part of the Goodies package:
..., limit the number of polygons, etc.
‎2019-08-15 11:23 PM
‎2019-08-16 01:27 AM
‎2019-08-16 08:35 AM
Noémi Balogh
‎2019-08-18 11:14 PM
‎2020-02-04 04:41 PM
nbalogh wrote:We are now in finishing stages of a teamwork project (School) and the performance of our file leaves a lot to be desired. We do have a lot of custom objects loaded to this project - some are archicad objects saved as custom with different preview picture (we have to specify products graphically to get around government limitations) others are even groups of AC objects to be listed as a single thing - kitchens for example. Until now we had them embedded in the project file, which adds further complexity with keeping the object up-to-date in both main files and modules. However, I hesitated to create a project-specific bim cloud library, since it is not recommended by GS. Could it however help with overall system performance?
Check the Embedded Library - if it has many objects, it makes working horrible in Teamwork. Empty its content and instead use objects as BIMcloud Libraries. This can be a huge improvement on performance.
