Project data & BIM
Plotmaker 3.1
After importing all DWGS into plotmaker, arranging on each sheet etc. I need to add one more room ele to the project.
Can't seem to find option anywhere, only import [filename].pln, which I assume I will need to rearrange everything again??
Is there an option to add?
Thanx
_____________________________________________
ArchiCAD 8.1 R2 AUS/Win XP Pro/Pentium 4/3.2gig/512 ram
Tom wrote:
Can I change the layer designation of multiple elements?
select them, then "edit selection set" command available as
- ctrl-shift-T, or
- Edit menu, or
- little button to left of layers in Info box
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks Karl!
I went to the Edit Selection Set window many times but never put 2 and 2 together.
