2004-06-24
11:27 PM
2025-01-30
12:25 PM
Molinda Prey
2004-07-16 04:06 PM
Drawing Scale and Output Scale will always displayI have been using the drawing scale in the titles and it picks up the scale of the imported drawing. perhaps you could use this method
"1:1." For PlotMaker all other AUTOTEXT items will work correctly in
both Projects/Drawings and in Master Layouts/Layout.
I just wanted to be clear that Drawingscale command just doesn't work
at all or does it when you print the document?
